TwinTurbo.NET: Nissan 300ZX forum - Compression Test with Plenum removed
johnbsz
on May 26, 2011 at 6:31 AM
Any reason I can't check the compression while I have the plenum pulled? I will pull the fuel pump relay first and will have to reconnect the battery ground.
Compression Test with Plenum removed -
johnbsz
06:31:54 05/26/11
go for it. no issues (n/m)
aliaZ
06:35:16 05/26/11
Just be careful to not get anything in the lower manifold >>
ZUL8TR
11:22:00 05/26/11
Yes, the engine should be warmed up
DAYTONAZ
19:03:05 05/26/11
it doesn't make that much of a difference
aliaZ
19:35:00 05/26/11
Yeah...agree...it is handy to be able...
ZTurboFan
20:25:13 05/26/11
Yep 2nd - have done with the plenum off too, works fine.
jzack
21:40:39 05/26/11
